MEP-005a voltage regulator repair diodes
Sephirothq
26
Trevorton / PA
My MEP-005a is only making around 100 volts. The voltage control doesn't function. Previously it worked.
So reading around it seems like the diodes in the voltage regulator are bad.
Removing the board, the diodes on the voltage regulator look swollen and corroded.
I removed the gel covering the board with a heat gun and small pick. I remember seeing that here.
Now what I am looking for is the diode part numbers to replace the 12 diodes on the board. There are 3 areas, one with 9, one with 2 and one diode by itself. So a total of 12.
Let me know if you know the part for those diodes.
thanks
