Mep-005b
Clint Sands
Shabbona IL
I just acquired a 30kw MEP-005B generator and was looking for the process to convert it to single phase. I searched here and on Google and was able to find conversions for MEP-005A but not MEP-005B. Is there any difference in the conversion of the MEP-005A and MEP-005B?
coxju04
55
Avery, Tx
I willing to bet you that it's a 400Hz. If so It's good for nothing other than running lights. Or if you are planning to run a radar station, it would work great. But to answer your question it conversion would be the same as the Mep-005a
DrillerSurplus
Salt Lake City. UT
I think the sequence started with the MEP-005, then newer ones became the MEP-805A followed by the MEP-805B. I'm not certain if the wiring is identical between the A & B models and you would want to be certain before you changed things around.
The 400hz models are MEP-815A & B
30kW TQG Generator Set, MEP-815A 400Hz NSN: 6115-01-274-7394 or 30kW TQG Generator Set, MEP-815B 400Hz NSN: 6115-01-462-0290
Guyfang
23,029
Burgkunstadt, Germany
Simply look at the data plate. This is obviously an:
MEP-005A, utility model, NSN, 6115-00-118-1240
MEP-104A, Precise model, NSN, 6115-00-118-1247
MEP-114A, 400hz model, NSN, 6115-00-118-1248
Yes it is encased in an ASK, (Acoustic Suppression Kit)
I can see at least 6 missing parts from the picture.
Clint, there is no such thing as a MEP-005B
