mep-006a diode suppressor
BMS07
23
Janesville,WI
I just picked up a mep-006a. Its missing a diode suppressor that is right above the day tank. What's it for? Its a little black box that has for wires to it. Where can I get one? Is it the same on different models? Thanks Brad
1800 Diesel
26
Santa Rosa County, FL
I believe that part is called the rectifier assembly. Inside the "cube" are diodes which have something to do with fuel pump operation. I believe the float switch circuit is also related. The TM provides more details than I have in my head... I don't have any MEP5s or MEP6s but I suspect the rectifier assembly is the same as found on an MEP4. You can check the TMs (parts list) to confirm whether the NSN is common for all three models.
Kevin
