- 6,850
- 670
- 113
- Stratford/Connecticut
I have a MEP-006a 60kw gen. I have used these gens before without issue. I just got this one and cant seem to get it going. New fuel filters installed, I get good fuel feed to the injection pump but none into it. This pump has the internal fuel solenoid and there is 24 volts to the contacts. The return line and ball valve are clear. The engine will run off a bit of ether. I did try opening an injection line in case the pump itself was air bound but I still dont get any fuel. I believe the 1/2 bolt on the side of the pump is for priming also. Other posts have talked about a manual shutoff under the top cover but before I start opening the pump up I was wondering if anyone with more experience could give some guidance here.
Will
Will
