vamellos
- 7
- 3
- Culpeper Virginia
Hello all - I'm new to the site and it seems like a tremendous resource. I recently purchased a MEP-006A on GovPlanet. After replacing the day tank fuel float the engine starts and runs beautifully. I am having an issue where the generator does not make power. The symptoms are identical to those i've sen on several older threads. If I hold the start switch on, the frequency reads 60 hertz and all the gauges read the proper voltages. When the switch is released the power does not stay on. I replaced the voltage regulator with no luck. I then sent the excitation assembly out to be refurbished. No luck. If I hold the start switch on after starting the unit, then release the switch, I get a reverse power warning light. The reset switch clears that warning light. I'm planning to check the K5 relay next. The manual says to disconnect the battery and the connector to the voltage regulator, apply 24 volts to terminals 13(+)and 15(-) on A5 assembly (I see those). Check continuity between terminals 1-14 and 2-15. Where are these terminals?
Reading some other threads on wet stacking, I'm wondering if i bought too large a unit. I have a blacksmithing shop and plan to use the generator to run a forging hammer with a 20HP motor that starts under a pretty heavy load (very large flywheel). Probably too much for a 10KW unit, but 30KW would probably be plenty.
Any advice is welcome.
