- 6,849
- 667
- 113
- Stratford/Connecticut
I have a mep-006a it has no power to the electric fuel pumps and no power to the day tank solenoid or relay. No power to the fuel cut solenoid unless battle short switch is on. Still no power to electric pumps or day tank solenoid with battle short switch on. Fuel pumps and day tank solenoid and relay have been manually tested and verified. I couldn't find a schematic that showed power path to the fuel pumps that would be a big help. The manual I have is older I didn't see troubleshooting steps for my issue. I swapped the overspeed sender, tactical relay box and the large special box with known good ones. No change in symptoms. It does crank properly. I looked over wires and connections everything looks good.
