mep 006a
Denny
spencerville Indiana
just wanting to get some opinion about the mep006a generator I just bought one for 2900.00. i am trying to decide weather to keep it or not . can you tell me are parts available thanks
Denny
I am new to this hope this works I plan to use this for home back and small shop wit some 3 phase wood working equipment . just not quit sure how to mix the to
Suprman
670
Stratford/Connecticut
You can run 3 phase equipment and tap off the 2x 120 volt legs for single phase use. Unless you plan on using at least 40kw worth of 3 phase power on a regular basis then the generator is just too big. They need to be run at capacity and it will just damage the gen using it for small loads all the time. Sell it and get a MEP803a 10kw. You can set it for single phase house use and then switch it to 120/208 3 phase to run shop equipment when needed.
Will
Suprman
670
I have a pair of big industrial 3 phase heaters they are supposed to be 15kw draw each. The two of them running together show around 30% draw on a mep006a. Unless you have a lot of equipment to run or a 3-phase load bank its hard to load them up.
Suprman
670
No. It's also of power for single phase use. Unless you plan on powering your entire block. The 10kw gen is plenty of power for most uses.
Guyfang
23,030
Burgkunstadt, Germany
I agree with everything Suprman has said. Too much gen set.
There was an add on load bank kit for this gen set. A kazillion of them were produced. I am sure there are still some out there someplace. Take the time to download the manuals from SS, and check it out. IF you can find one, if it is in working order, you could use it. But your fuel consumption will be, HIGH.
Its simply better to get a smaller gen set. Sit down, and figure out what you really need. You can get a clamp AMP meter, and hook it up. Turn on EVERYTHING in the house, and if the shop is wired to the same power source, turn EVERYTHING on there also. Then you have an idea what is the max load. That way you can figure what size gen set you need. Unless you are a real power hog, I can not imagine you needing, at most, more than 15 KW. But then I have no idea what's in your shop.
Sell it to some one who has a saw mill. They can use it.
