JOBRLA
- 8
- 3
- Las Cruces ,NM
Morning all, newbee here. I picked up a 2008 MEP-016B unit with only 2.7 hours on it. Flushed every thing and added new oil and fuel. I was unable to prime manually , had no resistance at all. Removed the pump and disassembled. There were no sign of gunck or sludge. Diaphragm in good shape. With pump off, I can make the manual prime work. Re-installed and tried manual prime again. There was resistance on first pump the went back the way it was. Backed off the 3 bolts just a quarter of a turn and I heard the diaphragm pop up. Tried manual prime and works. Tighten bolts down and does not. Removed pump and placed finger on cam rod and turned over. Rod extending properly. Re-installed and same thing. Pump only will manually prime with bolts backed off. Any suggestions? Thank you in advance
