Isaac-1
- 50
- 48
- SW, Louisiana
Well I picked up the MEP-701a / MEP-016B from government liquidation yesterday, it just needed oil, fuel and a new (pair of) batteries to get it running. It is making power (tested with a 1500 watt heater only so far) and it seems everything is running fairly good. Now down to the question, according to the TM the frequency should be set using the throttle upon start up, I set the freq at 60 hz and if I apply my 1500 watt heater test load it will maintain frequency (in fact by listening to it you would not know anything had happend), for now I am using the convenience outlet so this load does not show on the amp meter and does not run through the main breaker. The frequency will however slowly drift over a minute or two regardless of load from about 58 - 62 hz, I am wondering if this is normal for these units, or if there is something I need to address. (note from a cold start the frequency will tend to drift up 4-5 hz in the first minute, then this slow drift up and down begins), I only have about 30 minutes of run time since picking it up so it may just need to get the gunk out of its system. I have posted this same question over on the smokstak generator board, so hopefully someone either here or there will have some experience with this model.
Ike
p.s. I suspect this unit did not sit up for too long as the military 24 volt battery still had about 6v in it, but does not seem to take a charge (5 hours on my 24v charger at the 2 amp rate only brought it up to 14v).
Ike
