Icesythe7
- 223
- 43
- Indiana, USA
Traded for an mep-016b that looks like it has been sitting in the middle of the forest with no oil filter or fluids in general for about a decade, brought it home degreased and powerwashed the 17 pounds of acorns, ants and dirt out of it, brought it inside and wouldn't fill the new oil filter and was blowing exhaust out the intake only, thought it was the valves so made sure they were free and readjusted them as per the user manual still the exact same outcome. I then ignored that for the time being and the entire fuel system seems to work fine even the auxiliary fuel pump, while turning it over only white smoke out the intake nothing from exhaust other than sucking in air then I noticed if looking at it from the control panel the engine was turning clockwise (looking from the fan side counterclockwise), I assume this is wrong so looked at the starter and it is an ONAN 191-1550...should it not have an ONAN 191-1618 on it? I think my only issue with it at this point is engine spinning backwards but was hoping someone could confirm...and if so would that keep oil from filling the oil filter?
