maxf15
- 0
- 0
- Kathleen GA
First post... but yes, I did try to search for a similar problem first. ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I recently bought two MEP-016b's at govliquidations. Brought them home, no parts missing, only one wire needed to be spliced with a wire nut. Added new oil, fresh fuel, followed the starting steps, cranked over fine, but neither would start. (0.2 hours on one unit - the one that needed the wire spliced; and 249.0 on the other.)
So, I slowly pushed the throttle linkage open (counterclockwise) while cranking and rattle, rattle... they jumped to life. As long as I held the linkage open about half way, they purred like they should, rpm's varied appropriately as I manually opened the throttle. But as soon as I let go, they shut off. Even tried pulling the throttle cable all the way out to max throttle, but it will not stay running at idle. Held towards the middle, all is fine. Let go and caput.
I'm not a certified mechanic, but certainly mechanically inclined. And I know it could be any number of things.
Hoping someone has had experience with something like this. Just trying to get these units to idle without manually holding the throttle; I'll fine tune afterwards.
Merry Christmas!
Merry Christmas!
