Max Bladwin
- 1
- 8
- Michigan
Hello,
I could use some help troubleshooting an issue with the fuel pump that is between the day tank and belly tank on my MEP-016D with a Yanmar engine.
The issue is it never fills the day tank.
Here is what I have tried and observed.
For testing purposes I have bypassed the float switch in the tank and still have the issue. I have tested for voltage at the pump and it is about 60v. With the unit off I have hooked 24v directly up to the pump. I hear a single click and when I remove the voltage a small amount of fuel will come out of the hose. If I did this over and over it would eventually fill the tank. Is there some kind of electrical component that makes the pump oscillate or does it run non stop of current is applied?
