Max Bladwin
- 1
- 8
- Michigan
Hello,
This is my 1st post so bear with me. I have an issue with a MEP-016D with High voltage. It runs at about 170 volts at the convenient ports. The Hz meter is also not functioning. It has a stock voltage regulator. You guys have any thoughts on if this a voltage regulator problem or what to check? I am use to working with 015a's and this is a little over my head.
