MEP 016D Hook up
Jries
Maryland
Ive been playing with my newly purchased MEP 016D. I decided to keep the lugs rather then hard wiring outlets so that I can keep the versatility of the unit. I want to run it in 250 1ph to power a transfer switch. Which lug should I be using for the neutral and ground? And for the 120 mode? FYI I dont have any continuity between the ground lug and any of the terminals. Also my understanding after reading some other posts about OSHA requirements for grounding is that the unit itself shouldnt be grounded if using another ground, ie a transfer panel hooked to the main panel ground.
Jries
Maryland
Ive spent the day reading, and re-reading posts about this topic and am still confused. When I run my genset in 240V 1PH I have 120V L1-L0 and 120V L2-L0. However when I check the continuity of T6 to see if the mod has been done I only get continuity to L2. Also when I run it in the 120V 1PH mode I get 60V from both L1-L0 and L2-L0. I also only get continuity between L1-L2. I have no continuity to the ground lug all read as open.
I think my genset might be a misfit. I have no breaker on my float, no starter, and no slave recp.
