MEP-017a Dead - Loud Crack When Starting
warteetee
Pennsylvania
This is for the MEP002a and not the 017 gas that I listed - got my units mixed up.
I went to fire up my 5kw unit today to get the fluids moving and primed the unit as normal and then when I was in the pre-heat mode, I head a large firecracker like crack and everything went dead. Norhting on the panel works at all.
Since there are no fuses, I have no idea where to start to figure out what blew - any thoughts what might have been the item that failed so that is a easy place to start? Any other thoughts?
PeterD
Jaffrey, NH
FWIW, I have had glow plugs blow like this in 6.5 engines. In that case, it blew the terminal completely off the glow plug body.
warteetee
Pennsylvania
Carl - you are correct. I listed this wrong. The gas MEP017a is in the barn and not the issue. The issue is the MEP002 whic h is the diesel with the pre-heat.
**** - you are good.
I hooked the batteries back up and now I get the lights on the panel (before just all dead) and K2 behind the panel just buzzes when I go to pre-heat and then to start before it just clicks. Appears K2 is dead - Saturn the best place to find a replacment?
