MEP-017A Generator Emergency RUN.
M114
Moris County, Stirling, NJ
My MEP-017A ran great until last week. Now, in order to start and keep it running, I must put the "Emergency Run - Stop Switch" in EMERGENCY RUN position.
Why? What is wrong?
Thank you,
Pat
Triple Jim
287
North Carolina
I imagine the Emergency Run position bypasses all the safety shutoffs like low oil pressure, over temperature, etc.. You should probably start by checking those sensors and see if you find one of them or its wiring in the shutoff mode.
leedawg
10
Napa / CA
Id have to agree with Triple Jim. And id suggest you not run it this way because its very possible that its not running for a reason because one of those sensors might indeed be telling you that a problem needs to be addressed. Most likely one of them just failed but its possible there is an actual problem with the set and your just overriding the safeties and it might cause more damage to the set by allowing it to keep running.
Id start by tracking down all the fault sensors and testing them to make sure they work fine. Then move on from there.
