Mep 022
farmwelder2011
kooskia idaho
Was given a 5KW powerplant. 2 cylinder diesel. I will drain fuel and oil. Oil up the throttle assembly. And lite her off.
Any suggestions to not avoid any damage when first starting. Been setting 8 years . was running before storage. I did not see a compression release on the panel anywhere. does it have one. Once i get it running I may want to change the oil filter to spin on. any suggestions. Is it advisable to change the fuel filters to a spin on type filter.
Any tricks to changing the filter assemblies to maintain proper seal.. Any trailers available for this plant.
