Mep 026 3kw
jrosbo
Vandalia Illinois
I have a little 3kw genset here that runs great with the exception of one small problem, it will dump a half quart of gas in the crankcase in 30 minutes of run time. Any ideas? The float and everything else on the carb seems to be working properly. When it is running it does not appear or smell like it is running to rich until the crankcase fills up with gas and the gas oil mix starts burning which makes for a good mosquito fogger. Is there anyway the gas can get straight from the pump into the crankcase?
mangus580
282
Western NY
Yes, your fuel pump is bad, and leaking gas though into the Crankcase. Get a new fuel pump from Saturn Surplus, and you will be all set.
G744
3,700
Hidden Valley, Az
Yep, the fuel pump is on top just to the left of the carb under a little sheet metal. They go west with the new gas easily. Saturn has them NOS cheap.
dg
G744
3,700
Hidden Valley, Az
Dang it, I look really numb when someone else beats me to a reply. Back to typing shcool, I guess!
dg
jrosbo
Vandalia Illinois
Pump
Thanks guys for the info. I am learning about these things as I go. That little genset starts first pull everytime until the crankcase fills up then it won't. You take the plugs out and they are just soaked and the pistons are full of gas and oil and I mean FULL. You can pour the gas out of the plugs. Thanks again.
1,806
Joe, got manuals for the little guy? If not they are in the TM section of the site. One each for the engine and genset.
jrosbo
Vandalia Illinois
Manuals
I downloaded manuals off the logsa site but I could not find anything describing my problem. My printer is out of ink and nobody here local has my ink so I have to order it, but when it comes I am going to print the whole thing out. I just like the old fashion way of doing things. When you have a problem, grab the old paper version, head to the shop and try to fix it.
mangus580
282
Western NY
On a 'pro-electronic' note, some of the PDF TM's are search able by keyword :) Not sure if the ones in question apply though. It is dependent on if they were scanned or electronically converted.
jrosbo
Vandalia Illinois
manuals
Not knocking the electronic route, just like the paper better. I just find it easier to sit the book on the fender, just kidding. I do like to have both versions though, I keep the paper versions in the shop and the other in the house and they both have there place. I can print another one if the one I have gets worn out. I can look things up when I am at home (it takes me a little longer) talking to someone or ordering parts or late at night when I am trying to figure something out. Also the paper version could come in handy if the enemy cut your supply line. Just kidding again.
mangus580
282
Western NY
Yeah, I probably should switch to a paper copy when working on things..... I have a BAD story about using a laptop/tablet PC when working on a generator... rofl
Kenny knows all about it... ;-) I blame him!! :)
1,806
Not my fault Mike! I collect both versions of the TMs. When I'm faced with an area that I need the manual beside the item I'm working on, I just print the pertinant sections and go to work. No worried if they get all tore up, they just go in the garbage. On the other hand, I make copies of the wiring schematics and have them laminated. You can stick them to a fender or hood with magnets, works great.
BFR
Rocket Surgeon
2,331
North Georgia
when I was working on the model A I copied and laminated entire chapters of a shop manual I had. covered maybe 70 square feet of the wall
