Keith_J
- 1,316
- 113
- Schertz TX
Finally got one of those round toits and dug into my 026C (3kW 28 volt DC version of the 016C). I had fixed the carb and fuel system, starts and runs fine but even with the voltage adjustment in the lowest position, output is 35 volts. The voltage adjustment works, peaking out at 44 volts. That variable resistor is fine, linear between 0 and 750 ohms per specification.
I fear the voltage regulator has failed from the previous owners/operators running it at lower engine speed than 3600 RPM as I had to adjust the governor for proper speed and droop. I tried running it at lower speed and that works to get lower voltage output.
I've yet to load test because I don't want to fry my load bank, namely as a battery charge and jump system.
The -14 TM is vague on high voltage output. But it could be the power transistors?
