- 2,034
- 3,280
- 113
- Pepperell, Massachusetts
Remote Start Controller Kits For use in MEP-1030 & MEP-1040 Generators
Wi-Fi Remote Control & 2-Wire Start/Stop with live Parameter Reporting and Data Logging
Features include:
· Remote genset Start/Stop over Wi-Fi via cell phone, laptop, tablet
· Direct Wi-Fi communication. No router needed. Works during power failures.
(Version also available with home Wi-Fi network integration)
· 300 foot plus WiFi range. Password protected
· Browser display of all engine and generator operating parameters on remote Wi-Fi device. Parameters nearing extremes are highlighted in red text.
· Ambient Temperature
· Battery Voltage
· AC Voltage on each output leg
· AC Output Frequency reading to 0.1 Hz
· Load Current on each leg
· Output Power (kW)
· Fuel Level
· Coolant Temperature
· Oil Pressure
· Remotely Enable and Disable the Auxiliary Fuel Pump system
· Remote control of the Contactor with the Contactor state displayed
· User calibration of all parameters
· Data Logging of all parameters as well as engine hours and Start/Stop count. Min, Average & Max values logged every 10 seconds.
· Two wire remote Start/Stop for use with ATS, Solar Charge Controller, Toggle Switch or other contact closure
Additional features
· User programmable durations and delays for all phases of startup and shutdown. Separate delay settings for Wi-Fi Start/Stop and 2 Wire Start/Stop
· Warm up
· Stop command to contactor open delay
· Cool down delay
· Wire harness uses Mil Spec Wire rated to 300F
· Antenna and connector are IP65 rated for water resistance
· Retains full manual control of the genset
· Controller is conformally coated to seal out moisture
· Includes Controller, wire harness, all hardware for installation & manual
· 1 year warranty
I personally assemble each of the Controllers and wire harness.
Once built each Controller is fully tested and calibrated.
Each wire harness is tested on a computer-controlled cable test system.
Ordering Information
Cost: $1,000 Includes USPS Priority Shipping in the US
PayPal & Checks accepted.
To order email me at: kurtklopp@gmail.com or PM me here on the forum
Be sure to include the following information:
1) Name & Mailing Address
2) Payment Method
4) PayPal email address if using PayPal
Controller Circuit Card Assembly
Pre-Assembled wire harness
Complete with all Installation hardware and two drill bits
Sample web page when running under Wi-Fi control with live parameter reporting
Sample phone screen of Min, Av, Max statistics table
Link to YouTube video about the system
Feel free to PM or email me with any questions!
