MEP 1040 for Off Grid Travel Trailer and Temp Power for Construction
tmuenster
111
31
TN
I am writing to request advice or ideas for wiring a MEP 1040 generator to use at my off grid homestead site. I would like to use the generator for a couple of purposes-
1) Shore power for my small travel trailer that uses a typical 30 amp RV plug
2) Temporary power in the field for powering tools while building my cabin and shop buildings
My initial idea is to use a 30 amp RV receptacle wired to the generator with the weather head box attached to the outside of the generator. The generator would include a grounding rod. A standard RV shore power cable could then be used to plug into the travel trailer. Please see attached photo of 30 amp receptacle from Home Depot that I am planning to use.
Temporary power could also be plugged into the 30 amp receptacle. My idea is to wire an old salvaged breaker box with some 110 receptacles on a few of the breakers. The main feed to the panel would be wired to a RV-style shore power receptacle. The same RV shore power cable used to power the travel trailer could then be used to power my temporary power panel.
I look forward to hearing from the experts in the Steel Soldier’s community if you have used a similar setup or have suggestions to improve this idea.
Digger556
823
Denver CO
Are any of your tools 240V?
30 amps at 120V through an RV plug maxes out at 3600 watts. That is not enough to keep a 1040 from wet stacking. Even a 5kw generator would easily handle this and its likely the average load would be much lighter.
If your loads are limited to 3600 watts, you may be better served by a smaller Honda inverter generator or if you have loads with heavy starting needs, a 3kW power inverter run crom batteries and solar.
Also, +1 on the spider box. They are real handy around job or event sites.
tmuenster
111
31
TN
Many thanks for the advice. I am looking into a Spider Box.
I do have a small Honda 2200 watt generator but it is not quite enough to run the AC in my travel trailer with everything else. It’s been fine this winter but I know there are some long, hot days coming in TN. :)
tmuenster
111
31
TN
I did some research on ‘wet stacking’ and decided my little trailer would not draw enough power for MEP 1040 to run efficiently. I did some research and found a “soft start” for the AC on my trailer that allows the Honda EU2200i power up the AC while still having enough power for everything else. I also have my EU2200i running on propane which is nice since I have a 1,000 gallon LP tank at the site. The soft start and LP conversion system for my generator were purchased from HutchMountain.com. They have great support but the parts are not hard to install. IMG_1560.jpeg IMG_1500.jpeg
