MEP 16-E fuel problem
vinceM920
CONWAY, AR
Guys I have a mep 16 e with Yanmar engine. Last year it ran like a champ. I drained the old fuel and filter and pumped new fuel all the way to the injector pump. Now the injector pump will not pump to the injector. Can the injector pump be taken apart and cleaned? If so does it have to be timed back? If it cant be cleaned where would I be able to buy one? Also does it have a electric fuel solenoid shutdown that could be stuck that I'm missing. I don't see anything other than the elec. solenoid that pushes the governor wide open. I just want to eliminate everything before I pull the injector pump out and maybe screw something up. Thanks.
