MEP-16 Starter and associated parts installation
Boatcarpenter
17
Marlborough, NH
Does anyone have the complete instructions(including wiring diagram, etc.) for installing a starter, slave cable recpt.,starter switch and so forth on a 3KW gas generator. TM's I have only have rather vague pics.
Thanks,
BC
Boatcarpenter
17
Marlborough, NH
ACE, I have the starter,slave receptacle and mounting bracket already but no starter switch. I can get a switch but I'm not sure where the starter switch gets it's power and where it goes to. The small terminal on the end of the solenoid seems to be Neg. based on some continuity testing I did. I thought it should be Pos. to jazz the solenoid. That has me somewhat confused, which is not too unusual :? l
BC
ida34
32
Dexter, MI
My ford tractor has a negative trigger solenoid. Western snowplow systems use them to to activate the pump motor. They get the + from one side of the solenoid and the negative input trips the solenoid. This may be a similar arrangement.
1,806
Prentice, I'll see of I can drag out the 016 I have tomorrow and confirm the wiring.
JB
Tallahassee/Havana
Bumping this up. I have a starter, slave port, and a starter button. Any help on mounting starter would help. Looks like it will require almost a complete disassembly of the gen. to fit up in there.:shock:
