MEP-802/803 Filters and Parts
Daybreak
2 Star Admiral
767
Va
MEP-802A ONAN DN2M 2-cylinder engine (Lister-Petter LPW2)
MEP-803A ONAN DN4M 4-cylinder engine (Lister-Petter LPW4)
MEP-802A Filters List, MEP-803A Filters List
Oil Filter Spin-On (FILTER ELEMENT,FLUID NSN#2940-01-154-5127 )
Prefer WIX 51374, Napa 1374, works also(WIX 51348, NAPA 1348 ), FLEETGUARD LF3335, BALDWIN BT223, DONALDSON P550335, FRAM PH3614, PUROLATOR L10241, CHAMP PH2835
Fuel Filter cartridge (FILTER ELEMENT,FLUID, CARTRIDGE NSN#2910-00-099-5467 )
WIX 33348, NAPA 3348, FLEETGUARD FF4012, BALDWIN PF-847, DONALDSON P13, FRAM C11941, PUROLATOR F53121
Fuel Filter, Spin-On Fuel/Water Separator Filter (FILTER,FLUID NSN# 2910-01-376-5666 )
True Military filter with drain connector 85285-F
Alternate replacements, with bottom drain, but, factory drain with hose does NOT connect WIX 33472, NAPA 3472, FLEETGUARD FS1251, BALDWIN BF1226, DONALDSON P550248, FRAM P8043, PUROLATOR F64424
Air Filter (FILTER ELEMENT,INTAKE AIR CLEANER NSN#2940-00-934-7989 )
WIX 42276, NAPA 2276, FLEETGUARD AF435KM, BALDWIN PA1690FN, DONALDSON P181050, FRAM CAK256
There are many other filters out there. The best is a quality filter for a good price.
Oil Type
15W-40 Heavy Duty Diesel Engine Oil
Same thing here, whatever oil you want to use.
Coolant
Heavy Duty Diesel Type
MEP-8xx serpentine belt
Goodyear 4040355 Gatorback Serpentine Belt, Gates Micro-V AT K040355
MEP-8xx Fuel Tank Drain
Fuel Tank Well Nut A3816
MEP-802A 5kw generator
The military is currently using Optima Yelloptop 51R batteries x 2 in series for the 24 volt system
MEP-803A 10kw generator
The military is currently using Optima Redtop 34/78 batteries x 2 in series for the 24 volt system
Daybreak
2 Star Admiral
767
Va
Howdy,
All the manuals you will need to do anything with your units are here on Steel Soldiers.
All the manuals for the MEP-802, 5KW Generator and MEP-803 10KW Generator
MEP-802A and MEP-803A manual information
MEP-802A manuals you should have
TM 9-2815-252-24_____ Diesel Engine Model DN2M
TM 9-2815-252-24P____ Diesel Engine Model DN2M-1 Parts
LO 9-6115-641-12____ Lubrication Order
TB 9-6115-641-13____ Winterization Kit Tech Bulletin
TM 9-6115-641-10 ____ Operator's Manual MEP-802A
TM 9-6115-641-24____ Maintenance Manual MEP-802A
TM 9-6115-641-24P____ Maintenance MEP-802A Parts
MEP-803A manuals you should have
TM 9-2815-253-24_____ Diesel Engine Model DN4M
TM 9-2815-253-24P____ Diesel Engine Model DN4M-1 Parts
LO 9-6115-642-12____ Lubrication Order
TB 9-6115-642-13____ Winterization Kit Tech Bulletin
TM 9-6115-642-10____ Operator's Manual MEP-803A
TM 9-6115-642-24____ Maintenance Manual MEP-803A
TM 9-6115-642-24P____ Maintenance MEP-803A Parts
Daybreak
2 Star Admiral
767
Va
Howdy,
I would also look into finding a local NAPA store. NAPA list 6,000 stores across the USA. I am sure there is something nearby.
Daybreak
2 Star Admiral
767
Va
Howdy,
The second post has links to threads which should be read for MEP-802A and MEP-803A owners
Daybreak
2 Star Admiral
767
Va
Howdy,
A good collection for MEP-802A filters
A good collection for MEP-803A filters
StVeronus
San Antonio, TX
Does anyone have a part number for the actual secondary fuel filter housing? I am getting a leak from the bottom bolt/rubber gasket and need to either replace the housing or that gasket. Thanks in advance.
Guyfang
23,868
Burgkunstadt, Germany
You need to get a new gasket, (actually its an "O" ring). The housing is not the problem. The housing would be about 1000% more expensive then the "O" ring you need.
The part number for the "O" rings is: 186-6279-03, NSN is: No NSN.
The "O" ring is part of kit: part number: 393331, NSN is: 01-139-4010. The cost to the army is $18.00. its the whole filter housing.
Or Kit, part number: 7961121, NSN: 00-099-5467. Cost to the army is: $3,32. Its just the filter and gaskets needed to seal up the filter housing.
The last listed NSN was perhaps the easiest to get. Plug the NSNs into your browser and see what you come up with.
If you would download the TM's from the TM section here in SS, you could have also found this info. Or look at past threads. Mayhap that DAYBREAK has is in one of his threads/lists.
DorkFish83
Illinois
Awesome reference guide for these filters! I noticed a typo in the original post while pricing things out. The correct Baldwin air filter number is PA1690FN, not PA1960FN.
Daybreak
2 Star Admiral
767
Va
Howdy,
Good catch. I have a great NAPA nearby, so I have not needed the other manufacturer filters.
DorkFish83
Illinois
Howdy,
I was comparison shopping all the brands locally and online today, which was the only reason I found that typo. For oil, air and both fuel filters, the cheapest option ended up being Baldwin filters from Grainger. Even with tax and shipping it was still a few dollars less than Amazon, and almost $30 less than buying Wix at Napa.
Napa carries Baldwin filters as well, and their prices would have significantly beat Grainger's since I wouldn't have to pay shipping, but they didn't stock any of the correct ones and the guy said that they only do a Baldwin order every couple weeks, so that option was out.
It's a lot of work being a tight-wad... lol
-Tony
Sent from my XT1650 using Tapatalk
Guyfang
23,868
A better idea would be, for you to send me your money. I would of course hold on to it for you. For free! I would not charge you a thing! Nice guy that I am.
Feel free to contact me in New Zealand, whenever you need your money!
