MEP-802 Fuel Gauge Full all the time.
ECS
50
Florida
The fuel gauge is reading full all the time so it will not auto-refuel.
I suspect it maybe stuck, and if that is the case how do I free it up? I'm not sure how to check it?
Do you reach through the filler area or remove some panel?
or is it likely some other problem?
This thing is near new with only 17 hours. It had 12 on it when I got it and it ran until it ran the tank dry.
Thanks,
Zed254
466
S. Hampton Roads, VA
Check electrical connections and grounding. Then pull the TM and check out the diagram of .............
4 PAOZZ PAOZZ 36024 88-21162-1 .SWITCH LIQUID LEVEL 1
UOC: EMH
10 PAOZZ PAOZZ 30554 88-20061 ..SWITCH LIQUID LEVEL
I had to reach into the fuel tank and 'exercise' the liquid level switches. The floats sometimes hang up. You should check condition of the crud inside the tank, too. It might need some cleaning.
Guyfang
23,393
Burgkunstadt, Germany
Thanks,
The gauge has nothing to do with the replenish function. Two different functions. Would suggest you read the TM's a bit. The procedure for checking/inspecting the FL-1 and FL-2 functions, Engine shut off in low fuel situation and the replenish function are described in the -24 TM.
ECS
50
Florida
UOC: EMH
ECS
50
Florida
Thanks ... I see it now on the diagram.
