dependable
- 187
- 63
- Tisbury, Massachusetts
My 802 only fires on one cylinder cranking in cold temperatures, so, no start. My first guess is to check the "glow plugs" though that is not what they are called in TMs on this. I suppose it is possible a wire is loose or broken on heater relay also.
I probably have missed something, but the only references I have found in the TMs is to the "heater relay" in the gen set TM and a reference to the motor TM about testing and replacing of intake manifold heater plugs, which is brief and lacking in details. Not a lot of info that I could find.
Any one have some tips for getting at these? I guess I am going to try to get to them without removing top covers (I just re sealed them with calk a couple mouths ago).
The unit runs well once started, so it is not fuel or timing related.
Probably not the right thing to say, but if motor heater is down, and you need to start it, bend the air intake hose on air cleaner out of the generator housing and give it a very, very light squirt of either, without having used motor pre heat system (glow plugs). It is important to understand about pre ignition, piston fracture at the ring grooves, and the like, so you know just how small the squirt of starting fluid should be.
