MEP-802A and MEP-803A Modifcation
Guyfang
23,030
Burgkunstadt, Germany
I was looking at some old files and noticed this one. Having seen it happen once, and having to fix several others that had the consequences of the problem, it's worth looking at your set to make sure it's been done, or done right in any case. Its an easy fix. If you have ever seen what happens to a set that it hasn't been done on, and it shorted out, you know what I mean!
On the 5 & 10 kW TQG’s, if not already performed, rotate the slave receptacle so that the positive terminal is on top. This ensures that the wrench does not short out on the back terminal of the slave receptacle when disconnecting the battery terminal.
