Hi I just wanted to let everyone know that if you are using the genny’s at full load, you will need to change oil every 125 hours not the suggested 250 hours for regular use. I’ve proven this with oil samples. When it’s under full load, it kills the oil much, MUCH faster than at 50% load. These motors are a bit sloppy in clearance, so they let soot by when your under heavy load.
