I have attempted to look at the PDF's to see if they would help with the issue. I may need a pointer to the correct page as I didn't see a fix.
My 802A is not currently running. It cranks and will run on starting fluid, but it will no longer run on it's own.
I have verified that the full cutoff selenoid moves when attempting to start.
If I disconnect the hose from the location of the red circle, fuel will spray out.
I am open to ideas of other things to check. The generator was running last weekend.
I appreciate any help you can provide.
