MEP-802A Master Control Switch. It's an 88-21160 NSN:5930-01-368-5160
campwell
Salome, Az.
So what does everybody do when they need an Master Control Switch for there MEP-802A? I bought two MEP-802A's, one was missing the Master Control switch and the other one had a bad one.
-LARRY
campwell
Salome, Az.
The switch that was bad I took it apart and now it seems to be working fine. I checked with eBay no luck:( I think I might be able to take one off of one of my MEP-002A and see if that will work.
-Larry
kloppk
3,221
Pepperell, Massachusetts
Electrically it looks like it should work according to the switch contact tables in the two TM's.
Just need to use the correct terminals on the switch from the -002.
