MEP-802A MEP-803A Filters and Parts
Daybreak
2 Star Admiral
757
Va
Howdy,
MEP-802A ONAN DN2M 2-cylinder engine (Lister-Petter LPW2) Liquid cooled diesel, aluminum housing
MEP-803A ONAN DN4M 4-cylinder engine (Lister-Petter LPW4) Liquid cooled diesel, aluminum housing
MEP-802A Filters List, MEP-803A Filters List
Oil Filter Spin-On (FILTER ELEMENT,FLUID NSN#2940-01-154-5127 )
Prefer WIX 51374, Napa 1374, works also(WIX 51348, NAPA 1348 ), FLEETGUARD LF3335, BALDWIN BT223, DONALDSON P550335, FRAM PH3614, PUROLATOR L10241, CHAMP PH2835
Fuel Filter cartridge (FILTER ELEMENT,FLUID, CARTRIDGE NSN#2910-00-099-5467 )
WIX 33348, NAPA 3348, FLEETGUARD FF4012, BALDWIN PF-847, DONALDSON P13, FRAM C11941, PUROLATOR F53121
Fuel Filter, Spin-On Fuel/Water Separator Filter (FILTER,FLUID NSN# 2910-01-376-5666 )
True Military filter with drain connector 85285-F
Alternate replacements, with bottom drain, but, factory drain with hose does NOT connect WIX 33472, NAPA 3472, FLEETGUARD FS1251, BALDWIN BF1226, DONALDSON P550248, FRAM P8043, PUROLATOR F64424
Air Filter (FILTER ELEMENT,INTAKE AIR CLEANER NSN#2940-00-934-7989 )
WIX 42276, NAPA 2276, FLEETGUARD AF435KM, BALDWIN PA1690FN, DONALDSON P181050, FRAM CAK256
There are many other filters out there. The best is a quality filter for a good price.
Oil Type
15W-40 Heavy Duty Diesel Engine Oil
Same thing here, whatever oil you want to use.
Coolant
Heavy Duty Diesel Type
MEP-8xx serpentine belt
Goodyear 4040355 Gatorback Serpentine Belt, Gates Micro-V AT K040355
MEP-8xx Fuel Tank Drain
Fuel Tank Well Nut A3816
MEP-802A 5kw generator
The military is currently using Optima Yelloptop 51R batteries x 2 in series for the 24 volt system
MEP-803A 10kw generator
The military is currently using Optima Redtop 34/78 batteries x 2 in series for the 24 volt system
MEP-8xx Fuel return TEE 4730-01-357-8706
Onan part# 186-6177
Lister-Petter part# 751-13100
Generator Accessories Listing
The next post has quick links
Daybreak
2 Star Admiral
757
Va
Howdy,
All the manuals you will need to do anything with your units are here on Steel Soldiers.
MEP-803A, All the TM's you need
All the manuals for the MEP-802, 5KW Generator and MEP-803 10KW Generator
MEP-802A and MEP-803A manual information
MEP-802A manuals you should have
TM 9-2815-252-24_____ Diesel Engine Model DN2M
TM 9-2815-252-24P____ Diesel Engine Model DN2M-1 Parts
LO 9-6115-641-12____ Lubrication Order
TB 9-6115-641-13____ Winterization Kit Tech Bulletin
TM 9-6115-641-10 ____ Operator's Manual MEP-802A
TM 9-6115-641-24____ Maintenance Manual MEP-802A
TM 9-6115-641-24P____ Maintenance MEP-802A Parts
MEP-803A manuals you should have
TM 9-2815-253-24_____ Diesel Engine Model DN4M
TM 9-2815-253-24P____ Diesel Engine Model DN4M-1 Parts
LO 9-6115-642-12____ Lubrication Order
TB 9-6115-642-13____ Winterization Kit Tech Bulletin
TM 9-6115-642-10____ Operator's Manual MEP-803A
TM 9-6115-642-24____ Maintenance Manual MEP-803A
TM 9-6115-642-24P____ Maintenance MEP-803A Parts
Also TM's which cover the MEP on a trailer
All the TM's you need to work on MEP-802 Power Unit Trailers
All the TM's you need to work on MEP-803 Power Unit Trailers
Daybreak
2 Star Admiral
757
Va
Saved for further additions
Sticky Time :grin:
I would also suggest that you help support Steel Soldiers and become a member here.
What all do you get for upgraded membership? Increased PM box, access to the members only sections. Also we're looking to expand membership incentives, those are still in the works and will be announced later. (Looking at insurance companies, MVPA, and other things) Also, they'll be a new forum added in the members section related to firearms.
If you simply wish to toss a few bucks in to help us move to a better host, donations are accepted via paypal at: cstansbury@steelsoldiers.com
Thanks again for all of you who make this place great!
DieselAddict
1,900
Efland, NC
Does it make sense to publish all this info in a PDF and attach it to the thread containing the TMs?
Guyfang
23,002
Burgkunstadt, Germany
You know what I would say. Do it. All this info is needed on a daily basis. Maybe not you old timers, but the new Guys. And the simpler you make it for the new guy to find, the easyer it is to help them. AND, perhaps you can develop the the habit of people looking first, and asking second. There is only one dumb question. That's the question not asked. But some people will always ask first, because they don't feel like they have the time to look. Or are too lazy. If we have such a sticky, it tends to cut down on such people. The people who want to learn will love you for the sticky.
Daybreak
2 Star Admiral
757
Va
Howdy,
All your MEP-802/803 information and links to some important points.
Daybreak
2 Star Admiral
757
Va
Howdy,
We just bring it back to the top for the noobies to see and get up to speed.
Ray70
5,353
West greenwich/RI
Hello, I've been doing a bit of engine repairs on a bunch of these gens I bought and found a couple very cheap sources for full gasket kits ( $90 for 4 cyl.) , head gaskets, rings, bearings and such.
If you want to add to this thread I can send along some info.... The key seems to be to search ebay for Lister Petter LPW because most of what I found does not mention MEP-80XA or Onan DN*M in the description.
Daybreak
2 Star Admiral
757
Va
Howdy,
Original engine design = Lister-Petter
Authorized design = Onan
LPW2LPW4
DN2MDN4M
All the internals are the same. Pistons, rings, water pump, oil filters, injectors, valves, rockers, etc.. The difference is 1 being 2 cylinders and 1 being 4 cylinders.
Dock Rocker
72
Jackson ms
I am not sure why this isn’t a sticky. I used it again this week.
Thanks for putting this together for everyone.
