MEP-802A MEP-803A Filters and Parts
Daybreak
2 Star Admiral
1,522
775
Va
Howdy,
MEP-802a and MEP-803a use all the same filters and such
MEP-802A ONAN DN2M 2-cylinder engine (Lister-Petter LPW2) Liquid cooled diesel, aluminum housing
MEP-803A ONAN DN4M 4-cylinder engine (Lister-Petter LPW4) Liquid cooled diesel, aluminum housing
Oil Filter Spin-On (FILTER ELEMENT, FLUID NSN# 2940-01-154-5127 )
WIX 51374, Napa 1374, works also (WIX 51348, NAPA 1348 ), FLEETGUARD LF3335, BALDWIN BT223, DONALDSON P550335, FRAM PH3614, PUROLATOR L10241, CHAMP PH2835
Fuel Filter cartridge (FILTER ELEMENT, FLUID, CARTRIDGE NSN# 2910-00-099-5467 )
WIX 33348, NAPA 3348, FLEETGUARD FF4012, BALDWIN PF-847, DONALDSON P13, FRAM C11941, PUROLATOR F53121
Fuel Filter, Spin-On Fuel/Water Separator Filter (FILTER, FLUID NSN# 2910-01-376-5666 )
True Military filter with drain connector 85285-F
Alternate replacements, with bottom drain, but, factory drain with hose does NOT connect WIX 33472, NAPA 3472, FLEETGUARD FS1251, BALDWIN BF1226, DONALDSON P550248, FRAM P8043, PUROLATOR F64424
Air Filter (FILTER ELEMENT, INTAKE AIR CLEANER NSN# 2940-00-934-7989 )
WIX 42276, NAPA 2276, FLEETGUARD AF435KM, BALDWIN PA1690FN, DONALDSON P181050, FRAM CAK256
When looking for engine parts and gaskets, always search for both
ONAN DN2M or Lister-Petter LPW2 for 2 cylinder
ONAN DN4M or Lister-Petter LPW4 for 4 cylinder
Engines are all the same parts 2-cylinder or a little longer 4 cylinder. pistons, rings etc are the same.
There are many other filters out there. The best is a quality filter for a good price.
Oil Type
15W-40 Heavy Duty Diesel Engine Oil
Same thing here, whatever oil you want to use.
Coolant
Heavy Duty Diesel Type
MEP-8xx serpentine belt
Goodyear 4040355 Gatorback Serpentine Belt, Gates Micro-V AT K040355
MEP-8xx Fuel Tank Drain
Fuel Tank Well Nut A3816
MEP-802A 5kw generator
The military is currently using Optima Yellowtop 51R batteries x 2 in series for the 24 volt system
MEP-803A 10kw generator
The military is currently using Optima Redtop 34/78 batteries x 2 in series for the 24 volt system
MEP-8xx Fuel return TEE 4730-01-357-8706
Onan part# 186-6177
Lister-Petter part# 751-13100
Generator Accessories Listing
The next post has quick links.
Daybreak
2 Star Admiral
1,522
775
Va
Daybreak
2 Star Admiral
1,522
775
Va
Howdy,
All the manuals you will need to do anything with your units
are here on Steel Soldiers.
MEP-803A, All the TM's you need
MEP-802A and MEP-803A manual information
MEP-802A manuals you should have
TM 9-2815-252-24_____ Diesel Engine Model DN2M
TM 9-2815-252-24P____ Diesel Engine Model DN2M-1 Parts
LO 9-6115-641-12____ Lubrication Order
TB 9-6115-641-13____ Winterization Kit Tech Bulletin
TM 9-6115-641-10 ____ Operator's Manual MEP-802A
TM 9-6115-641-24____ Maintenance Manual MEP-802A
TM 9-6115-641-24P____ Maintenance MEP-802A Parts
MEP-803A manuals you should have
TM 9-2815-253-24_____ Diesel Engine Model DN4M
TM 9-2815-253-24P____ Diesel Engine Model DN4M-1 Parts
LO 9-6115-642-12____ Lubrication Order
TB 9-6115-642-13____ Winterization Kit Tech Bulletin
TM 9-6115-642-10____ Operator's Manual MEP-803A
TM 9-6115-642-24____ Maintenance Manual MEP-803A
TM 9-6115-642-24P____ Maintenance MEP-803A Parts
Also TM's which cover the MEP on a trailer
All the TM's you need to work on MEP-802 Power Unit Trailers
All the TM's you need to work on MEP-803 Power Unit Trailers
flainn
US
Hi all, as a very new owner of a MEP-802A, I immediately discovered two things: the coolant had all been drained out of mine, and the bottom radiator hose was in terrible shape -- in fact, when I pulled it off the twisting created huge cracks throughout.
The radiator hoses were challenging to find, but I did find one outfit that has the upper (88-20189) and lower (88-20190) hoses for $20 each. I figure if my bottom hose is in bad shape, the upper can't be far behind so I'll replace both.
The site I found them at is www.teamequip.com. I have no affiliation with these guys.
flainn
US
Howdy,
I know your new and all. Try to keep misc post in the regular forum area.
This thread is about MEP-802A parts. These hoses are MEP-802A parts. You'd prefer I started an entirely new thread for this?
mciikurzroot
235
wimberley texas
Mike Thank you much, and this gets me almost complete, and i have printed it and will place it inside my manuals, what can you offer me for the 804A/B i have both and esp need fuel filter info .. thanks again Daybreak mac/mc
Papi Chulo
15
Florida
Howdy,
Oil Type
Coolant
Onan part# 186-6177
THANKS FOR THE INFO, it really helps!
LuckeyD
396
Vilseck, Germany
This list for the 803 is a Distro A source doc. TMs are in the TM area of the forum. The latest 802 TM is Distro C, but I have an old Distro A TM. Waiting on a decision to post since it did go to C. These are 10 KW Schematics. I also have the AIT power points used for this gen. I made these myself but based on 803 TM schematics in B/W in the TM. There are notes in there to help you. The list is a 20 year conglomeration of TMs, emails, and factory all working together. Hope it is helpful. Everything has been tested for 20 years by thousands of GIs as they always wanted to prove Oby Wan wrong including the 6 like me on the planet. I'm still waiting. Ask Guyfang. Sorry I am also one of the EE nerdy guys but I was a bit different. The parts list also contains the VR slow blow fuse and connections as should the schematic, The fast blow fuse is in 15-60KWs. Saves your exciter and regulator. $$$$$ Do not be surprised if the main gen leads on you set at TB3 are different than the schematic but match a home made drawing I made up that usually matches after rebuild (not RESET) which changes the date of manufacture on the data plate (from another Post). Use Wire numbers to match up is the best way. I assisted making the unit RESET guide so I can answer a lot of Qs folks may have.
Summerpaws
206
33
Hampton, NH
If your 802 or 803 trips the overload below the rated listing, one possible cause is a bad burden resistor. If a resistor is open, the voltage going to the overload relay, K8, will be higher which will cause K8 to think there is a larger load than there actually is causing it to trip. This is explained in another thread. https://www.steelsoldiers.com/threads/mep-802a-trips-overload-at-anything-over-4000-watts.224570/
The resistors are no longer produced and a new one cannot be found. Mauser Electronics sells a resistor that can be substituted. It will fit in the space that the original one lives in with some small modifications. It is more robust and should live a long time.
Just so you have it, here is the resistor info.
71-RE70G7R50
RE70G7R50C02
Vishay Wirewound Resistors - Chassis Mount
Mouser Electronics, Inc.
Phone: 800-346-6873
orders@mouser.com
LuckeyD
396
Vilseck, Germany
Good Day everyone; R10, R11, and R12 are the Burdon resistors on 802 and 803 gens. They were procured thru Vishay Dale Electronics, 122 23RD Columbus NE 68601, 402-563-6296 for about $1.30 each for the military. These are 7.5Kilo Ohm 5% tolerance and all you have to do is open google and type in 20 Watt 7.5K Ohm wire wound resistor and google will fill your screen with them and choose what fits with a 5% tolerance. I found they seem to cost about 9 bucks a pop as I looked a couple minutes ago. They are just normal power resistors you get at a TV or radio repair shop. They are even at EBAY. These usually do not go bad unless they were over heated and this will show on the outside coating, corrosion, and I usually found them having the tiny wire sticking out. Should assist finding these as a replacement for what came in the gen.
Summerpaws
206
33
Hampton, NH
Good information! I carefully checked my burned out one and there is no visible damage. The best way to check them is with an ohm meter. Apparently some fail incognito. :cool:
