mep 802a -- mep803a source for panel meters
zarathustra
59
glasgow,ky
Does anyone have a known source for the panel meters on the 802/803?
Specifically, the 60 Hz meter, the % of rated current meter, and the AC voltmeter.
All the others are fairly straightforward, but I'm having some difficulty in finding the above three.
z
zarathustra
59
glasgow,ky
Thanks -- I don't believe he has any. His gens came from Crane, and they were stripped of gauges.
Still looking.....
zarathustra
59
glasgow,ky
The 11707 meter is not exactly the same as the "normal" one in an 802/803. However the differences center around the ability to withstand an EMP attack. In all other aspects they are the same thing.
Well, I don't think that we are in danger of an EMP attack at present, so the 11707 would make an excellent substitute.
Note to CRABBIE --- excellent discovery -- ya done good!!
z
m-35tom
221
eldersburg maryland
that's because when you search for 11707, you get all the meters they make. if you are not pickey about match there are many on e***
actual part numbers are:
freq 72-5016 or 638-18049
amp 72-5007-1 or 72-5007-2
volt 72-5008
disclaimer: while this info might be correct, check for yourself to make sure
