teletech
- 216
- 43
- santa cruz,ca
I know I need to RTFM on the TMs, but I'm juggling an awful lot so hoping for a little luck and grace here.
Recent purchase of a 2005 unit in non-working condition (so they say). Filters, oil change, fuel, batteries, replace some return fuel line and the incomplete holder for F1, and it starts and runs. Heck it even makes AC! It won't charge the batteries unless I momentarily hot up the alternator regulator with V+ and then it runs and regulates. My VOM says diode 1 is still a diode, so either my VOM is lying to me, the diode is being sneaky, or something else is up. Thoughts?
Fuel gauge doesn't read at all. I'll dig into it, but thought I'd mention it in case theres a "oh, this thing always happens" answer I should start with.
The most pressing problem is actually on the AC side. It makes power as I said, but seemingly randomly throws a overload error. It's done this in single-phase 220 mode charging an EV and genset load about 25% and also in 3-phase mode running a big 3-ph space heater (environmental control unit) and energy reading about 55%.
It never happens when I'm looking at the unit, but seems like whenever I turn my back it trips and the contactor opens up. Reset the fault and engage the contactor and you are back to making power.
I also replaced the external supply fuel pump, dozens of fasteners, and straightened some sheetmetal.
Thanks folks,
Thanks folks,
