MEP-802A: Onan DN2W, not DN2M engine?
RClark13
SE Michigan
20240226_140011.jpgI have an MEP-802A with an Onan DN2W engine.
Can anyone tell me if the W is a model change?
Having trouble locating lower radiator hose for this, I've tried a few vendors and they are either completely wrong, or, correct shape, but 1" ends, mine uses 1-1/4" on both ends.
All of the listings I have found, including tech manuals, list the Onan DN2M
TomTime
1,664
MD.
Here you go.
If you want to contact the seller, @Light in the Dark , and since your new, you will need to go through an Administrator.
Good luck,
Tom.
RClark13
SE Michigan
Thanks Kurt, I'm trying to contact them, being new here, I am awaiting admin to facilitate the conversation.
also fishing for info on the DN2W vs DN2M, not sure if there are any differences.
I have ordered hoses from a few vendors, all claiming there is only one style, yet none fit my lower, so not sure why I seem to have the only MEP802 with 1.25" lower hose???
Light in the Dark
5,658
MA
I don't believe there is any such thing as a DN2W someone at Onan must have been standing on their head when they set up the stamping machine the day that tag was stamped!
The casting on the block in the photo is curious too. I am sure they had more than one mold they used for this block. A little birdie told me that this 'fiercely British' company was having the Alpha blocks cast in the Far East... would make sense, as they recently were sold off to a Chinese engine manufacturer (though the Alphas and a single air cooled design, are still being produced under license in the UK).
