MEP-802A running on Bio-Diesel
BadRobot
Raleigh, NC
Does anyone run MEP-802A on bio-diesel? Is it feasible? What will be the side effects to the engine?
I live in a farm. I can pick up used oil from McDonald nearby and make my own bio-diesel.
Triple Jim
277
North Carolina
I'm not speaking from personal experience, but it's my understanding that if you make real biodiesel from vegetable oil, it is compatible with any diesel engine. The only difference is that it has a problem at very cold temperatures. It's straight vegetable oil that isn't tolerated by all diesel engines.
Daybreak
2 Star Admiral
760
Va
Howdy,
If you are running you mep-802a daily and putting hours on it, then it might make sense. Once the temp goes down below 32, you would be better off with real diesel fuel. The glaze point of bio which your talking about is fine when its warm out. The winter kit uses fuel to keep the unit warm ready to run in artic conditions. I would say with the pre-heat, and diesel, and being in Maryland, you will be fine without the artic kit.
DieselAddict
1,902
Efland, NC
Keep an eye on the rubber bits especially if you run home made bio. It usually has higher levels of residual methanol. That stuff can be hard on rubber.
jimbo913
33
Maryland
Are you already making bio or just thinking of making it? Most people who start realize its too messy or too much work and with off road Diesel at $2.00 a gallon its probably better/easier to just stock pile.
I have ran mixed in my non military generator but I replaced the fuel line with bio compatible hose.
