MEP 802a
oldman70
Cartersville, GA
MEP 802a generator stopped producing power, the Volts gauge showed 220 volts. Checked for power at the lugs and at the 110 outlet, no power at either. Any suggestions as what the problem may be. Any comments appreciated.
Zed254
466
S. Hampton Roads, VA
Did you close the AC CIRCUIT INTERRUPTER Switch to get power on the lugs?
For 110 outlet did you check the ground fault interrupter below the fault lights and the circuit breaker inside the control panel?
Might should post some of the known history of this machine, too.
