MEP-803 overheated first time under load
cstumpf750
30
13
The Jersey Shore
So I got a couple of 5000 watt heaters off Amazon to load test my generator. I put one of it just to see how things went with a partial load. Well, it overheated in short order. I shut it down before it did it via the sensor. seemed like the thermostat never opened. I found a forum post where the same thing happened and after it cooled down they pulled the thermostat and it worked when tested, so they put it back together and it worked fine. So I tried again today and this time the thermostat opened and closed repeated while under a 5000 watt load. I watched the gauge move back and forth several times before shutting it down. I still need to do a full load test, so I’ll keep an eye on it, but I think it should be OK.
I’ll get a spare so I have one if I need it. Does anyone know of a cross reference to a thermostat and gasket from an auto parts store?
FarmingSmallKubota
1,217
Wapakoneta, Ohio
Here you go
Also cheap ebay https://www.ebay.com/itm/196206324395
Toolslinger
227
PA
So, just out of curiosity... Where are you finding a Murry 15358? I went through every Murray thermostat on the O'Reilly site, and did not find that number.
I did find a 15358 at AutoZone, but not a Murray brand.
The only references to Murray having that number I find are here on Steelsoldiers, and then there's something in a Ram forum, but no manufacturer, or actual sales links.
That's not to say anyone is wrong... My opinion of search engine results has gone right in the toilet over the last several years...
Ray70
6,427
West greenwich/RI
Assuming your thermostat was installed correctly ( spring towards the engine ) I'd say you may have had an air pocket under the thermostat, preventing it from opening correctly.
Some thermostats have a small 1/8" hole drilled in the flat body with a little brass ball that acts like a check ball almost. It will let air bleed out but blocks the flow of water. If I get a thermostat without the hole I almost always drill a small 1/8" hole in it to help bleed the system. The 1/8" hole doesn't flow enough water to affect the operation of the thermostat at all, but it will allow air to bleed out easily.
2Pbfeet
1,036
Mt. Hamilton, CA
I've heard the gizmo called a jiggler. I know some newer thermostat designs have grooves cut in them to allow air to by pass the thermostat.
I've heard of the 1/8" hole trick before, though I have never needed to use it to get air to bypass a thermostat because in the past I had been able to find thermostats with jigglers for engines that needed them.
All the best,
BG
