MEP-803 rubber seal between radiator and shroud
warf
12
Arecibo, PR
Hello all;
Had to remove my radiator to have it repaired. The orange rubber seal between the radiator and shroud was loose and comletely came off when I removed the radiator. I cant find the part on the TMs. Can they be glued back or can I buy something like "Trim-Lok Solid Rectangle Rubber Seal" to replace it?
Ray70
5,826
West greenwich/RI
You can do either. Try gluing it back on. You may want to use contact cement, apply to both surfaces, let dry then stick together.
That stuff is a silicone open cell foam, maybe 10mm square or so?
Anything remotely similar will work just fine.
