LuckeyD
- 194
- 33
- Vilseck, Germany
Get her home; start at one end and work to the other. Slap a set of batteries in it (nice if they were old recharged).
Now look over the control box and wiring. If all looks well, with fresh oil in engine and water in the radiator ready for a flush, motor over the engine using dead crank. If all good; place s1 on run and listen for fuel pump action.
Open fuel drain and with hose look at what comes out the filter water separator. If all good try starting. May take a bit as injector pumps and injectors have to get primed.
Hope all is well as it settles down after awakening and you have a good one on hand. Now you can spend money to bring it up to your standards.
As the bolts break off removing panels numbers are available for the thousand clinch nuts and bolts. Some want it OEM, others use common sense. Let us know how it all goes. Good luck....
