Dave926
- 3
- 3
- Ft Myers Florida
I noticed my fuel gauge ran up past full when I ran it last and then went below empty and stayed there. Checked the resistance, none there. Open circuit right at the sensor. Tried to take out the sensor but it fell apart when I removed the top flange. I figure I can reach in from the filler spout and pull it out the rest.. I'll have to take out the spout and the fill flange. I noticed some serious corrosion on both the filler spout and the flange that wasn't there when I bought it about a year ago. It was manufactured in 2012 and rebuilt some there after. Had 2 hours on it. It looked brand new. Everything else is flawless. I bought diesel from a regular pump at a gas station and filled it up several months ago. Maybe this is a result of bio-diesel? I did not notice anything at the pump mentioning a blend with bio-diesel. I put nothing else in the tank.
I bought the replacement sender mentioned in another post that uses hall effect magnets instead of the swing arm. Got the 8.5 inch version. I stuck a dowel rod down the sender hole. Although it's close, I think it will clear the drop down side of the tank without the spacer. What kind of plastic will survive in the diesel tank? Does anyone have a picture of the plastic piece on the sender? I'll let you know when I get there. Has anyone who has installed these had to take the tank out first? The 8.5" may not make it due to the lack of overhead clearance.
As long as I have this apart, I was going to replace the aux fuel filter. I have the parts manual but could not locate it on the diagram. Does anyone know the replacement aux fuel filter number?
![Filler Spout 1.jpeg Filler Spout 1.jpeg](https://www.steelsoldiers.com/data/attachments/530/530468-54c9ed5502c8c406f8c8292a7c4e0d93.jpg)
![Filler Spout 2.jpg Filler Spout 2.jpg](https://www.steelsoldiers.com/data/attachments/530/530469-5941bcd19b01acde256da99d8b03f18d.jpg)
