Ray70
- 5,494
- 113
- West greenwich/RI
Hello everyone, I was wondering if anyone here knows what the typical cylinder cranking pressure should be on a typical LPW2 or LPW4 motor?
I've been working on several of these and I'm finding some at about 250psi and some closer to 200-220 psi.
From reading, these motors are supposed to be 18.5 : 1 compression, which should theoretically have a much higher cranking pressure, but I'm wondering if the large swirl dish in the top of the piston allows / causes significantly lower pressure?
I would like to know what others have experienced with cylinder pressures so I can be better able to diagnose combustion problems.
