mep 803a fuel relay 5945-01-378-7172 needed
1,176
Try Delk's.
DieselAddict
2,018
Efland, NC
SA-3865 is the number to search for. That is the civilian part number. You'll find plenty of sources for compatible units. I was posting the link to GMG to identify the part in question.
Guyfang
23,484
Burgkunstadt, Germany
When the part was ordered in the Army, it always came without the plug. So IF you can get a new one, DO NOT toss the old one until you have put the new one on the set. The plugs and pins are simple to install and remove, if you have the proper tools. If not, do like every good soldier has done for the last 15-20, years. Cut the ware harness off the solenoid, close to the body and attach it to the new one.
abbalogh
Mckinney TX
Sorry for the lack of info.
The SA-3865 is the fuel shut off solenoid on a Mep-802a. When I picked up my 120 hour MEP-802a from gov liquidation the fuel shut off solenoid assembly was missing. So I am trying to locate a replacement.
Guyfang
23,484
We tend to use the item name from the wire diagram, to make it simpler for everyone, not the part number. PM DAYBREAK, and ask him if he has one. He has lots of odds and ends. Also, look up the NSN no use it in your browser. The NSN will show more places to find it then the part number. Also, look at message 11. If you get a new one, you are also going to have to source the plug.
