MEP 803a generator
Jason Y
Sparta, WI
I am looking to hook up an air compressor to the lugs, just a simple single phase, 3 wire hookup. Question is which lugs do I hook the cables up to (White, Black and Green). It has an L1-L3, L0, and a GRD. My guess is L1 and L3 and the GRD since that is the way it was setup and worked on a Magnum 80 wheeled generator with the same lugs minus the L0.
2nd Question How do i tell if power is going to the lugs, to see if its working properly or not. Cause right now with the way i have it hooked up i get no power to the compressor, which leads me to beleive the lugs arent getting power? Or am i not thinking right on it.
I have very limited electrical knowledge, so please be gently with replies lol. Thank you.
Scoobyshep
1,163
Florida
Need to know what the compressor voltage is.
Do you have a multimeter?
Guyfang
23,397
Burgkunstadt, Germany
Is this set new to you?
Have you ever seen it work right?
Have you downloaded the TM's from the TM forum and read the operators TM?
When you turn on the CB, (Circuit Breaker), there is supposed to be a light that comes on when the CB closes. Do you get a light?
