tscott8201
- 0
- 0
- Keystone Heights, Fl.
What type and gauge of wire are you all using to replace the existing glow plug harness?
Tom
Tom
AAGR | CROSS-SECTIONAL SHAPE STYLE | ROUND |
ABJH | TEMP RATING | 105 DEG CELSIUS |
ADVL | CROSS SECTION OUTSIDE DIAMETER | 0 6/25 INCHES NOMINAL |
BLNZ | STRAND QUANTITY PER CONDUCTOR | 133 SINGLE CONDUCTOR |
CXCW | CONDUCTOR FORM | STRANDED SINGLE CONDUCTOR |
CXDC | ROUND CONDUCTOR SIZE | 8 AWG SINGLE CONDUCTOR |
CXDG | STRAND AWG SIZE PER CONDUCTOR | 29 SINGLE CONDUCTOR |
CXFK | VOLTAGE RATING | 600 MAXIMUM ROOT MEAN SQUARE (RMS) OPERATING VOLTAGE SINGLE CONDUCTOR |
HUES | COLOR | WHITE 1ST POSITION COVER SINGLE CONDUCTOR |
MATT | MATERIAL | COPPER ALLOY 101 CORE CONDUCTOR SINGLE CONDUCTOR OR COPPER ALLOY 102 CORE CONDUCTOR SINGLE CONDUCTOR |
MDCL | MATERIAL DOCUMENT AND CLASSIFICATION | ASTM B33 ASSN STD ALL MATERIAL RESPONSES CORE CONDUCTOR SINGLE CONDUCTOR |
SFTT | SURFACE TREATMENT | TIN CORE CONDUCTOR SINGLE CONDUCTOR |
STDC | SURFACE TREATMENT DOCUMENT AND CLASSIFICATION | ASTM B33-63 ASSN STD SINGLE TREATMENT RESPONSE CORE CONDUCTOR SINGLE CONDUCTOR |
TEMP RATING | 105.0 DEG CELSIUS |
CROSS SECTION OUTSIDE DIAMETER | 0.240 INCHES NOMINAL |
VOLTAGE RATING | 600.0 MAXIMUM ROOT MEAN SQUARE (RMS) OPERATING VOLTAGE SINGLE CONDUCTOR |
FREQUENCY RANGE | 9.000 GIGAHERTZ MINIMUM AND 10.500 GIGAHERTZ MAXIMUM |
That was interesting!This should point someone in the right direction if they want to find it.
https://www.distributorwire.com/blog/machine-tool-wire/
Howdy,Quick google search for 8 gauge MTW should get you sources to buy by the foot: https://www.platt.com/platt-electri...tionID=15&GroupID=189&CatID=733&SubCatID=5658
