diogenescreosote
- 6
- 3
- Willits, CA
I bought an MEP-803A a year ago with 400 hours, and it now has 900 hours. It was working fine, as far as I could tell, and then one day it would not start, and it hasn't started since.
When I try to start it, there is no rumbling, the starter motor sounds like it's spinning free. A mechanic opened up the top of the engine and showed me an immense amount of hard carbon buildup where the exhaust leaves each cylinder. He said he suspects the rings are stuck open with soot, and that it will work if the head is removed and the whole engine is cleaned out.
In the 500 hours I've used the machine, I've run it at about 3.5 kW. I know diesel engines like more load than that, but I didn't think it would be so low as to cause this much buildup.
I have two questions:
- Was my running it at 3.5 kW the cause of this problem?
- Is cleaning everything likely to make it work?
