Triton
- 81
- 28
- Houston, Texas
Ok, I have no power at the lugs, here's what I have done:
this unit is a tier 2 reset with 600 hrs, has fuse mod and just quit putting out power
Unit running
Am/Vm switched to L3,L1 Single phase
Reconnection switch 120/240 1 phase
flipped ac interrupt switch to closed, green light comes on
Hertz at 60
No fault errors
Convenience plug reads 37 volts
No reading at lugs
Cleaned reconnection switch and AM/VM switch with deoxide cleaner
Hold S-1 to start and voltage comes up to 240 and it produces 120volts at convenience plug and 120volts on L-3 and 120volts on L-1, release S-1 and it goes to zero
One time (in band camp) it did come up with 240 volts on the gauge and at the lugs but hasn't done it since
Is there an easy fix? What do ya'll think I should check first?
Unit running
Hertz at 60
No fault errors
No reading at lugs
