MEP 803a parts?
Bmxenbrett
30
You should beable to just replace that rubber section with fuel hose. Cut the crimped ferrel off and hose clamp it.
Light in the Dark
5,882
MA
Yes you can use Gates hose from O reillys or similar. Right off the shelf, with hose clamps for the primary fuel lines, and zip ties for the return line. The "t"s in the return line are 1/8" plastic vacuum tees, should you have any that break.
