chilbun28
- 113
- 33
- Deep South
Quick question guys, MEP-803A (2010 with 500 hours) has power at the control panel and the fuel pump comes on when the main switch is turned to prime but there is no response from the motor when the switch is turned all the way to the start position. Pump comes on, panel lights work, but nothing happens when you turn the switch all the way to start. I'm going to get the generator from where it's at and bring it home early next week to start going through it, just hoping to get some good direction from anyone who has a little time to run me through the electrical path and most common points to check out. From what I understand there are no fault lights on such as no/low fuel... Generator turns over just fine with the dead crank switch. Anything to help get me going is appreciated.
