MEP 803A shorted battery
Louis9113
37
Louisiana
Hi,
I’ve searched SS but can’t find the answer. My dad was disconnecting the batteries and the loose terminal flopped and shorted, causing a large spark. He said the relay behind the instrument panel keeps tripping when attempting to start. He installed a new one and same thing. Any pointers as to what got fried when the battery cable shorted? Thanks!
nextalcupfan
508
St. Joseph Missouri
The only things I can think of that get energized in RUN/PRIME are the Fuel Shutoff solenoid and Alternator trigger wire.
but the Fuel Shutoff should be through a relay.
Personally I think I would take all the ice cube relays out and see if it still trips, while looking for potential wire rub outs.
These sets vibrate enough that its actually pretty common.
Personally I found a spot behind the main control panel that was starting to rub out.
Louis9113
37
Louisiana
Funny how symptoms and problems collide. My dad had disconnected the batteries (sparked cable in process), cleaned the terminals on the fuel gauge (primary reason for disconnecting the batteries), and just called to say that after 2 hours, he found that he had hooked the wires up incorrectly back on the fuel gauge. He called and I could hear it running in the background 🤷‍♂️
Guyfang
27,346
Burgkunstadt, Germany
You will never know how often this kind of thing happens. When ever I unhook something, I never mark wire with tape or other such nonsense. I look at the schematic. Its there on your set. So why not use it? Always check twice if not three times the wires. Know, instead of think. Be glad it was a simple fix!!
